Winch
Hello I have a question!
I have a 4x20 LCD connected to the DP0-PD3 port of an ATmega32u4 processor. The problem is that it won't work?
I suspect it has to do with the UART output of this port. But not sure.
I've already set up this design as a PCB. So I want to get it working on these PD0-PD3 outputs.
As a test, I imitated the same setup on an Arduino Leonardo and got the same picture.
When I connect it to eg PB4-PB7 port it works fine. So it's not the code. It must be the hardware.
Does it ultimately have to do with the fuses setup? Or should something else be done?
This is the image I get on the screen.
