That pattern looks like what you get if you lay the board flat to dry instead of on its edge. The remaining beads of water evaporate and leave deposits. Try a final rinse with distilled water.
Also, if you aren't using a heater roller, invest in the £200 or so to get one, you will be much happier.
That does not seem to be a problem. Rinising with distilled water is a good idea but I do not need to do it and our water contains a lot of minerals.I'm concerned about the paper towel leaving fibers and "sizing" contaminants.
That doesn't sound like a good idea. How 'dilute' ?I also "pickle" the board in a dilute solution of ferric chloride
The toner doesn't stick. It flakes off in an odd way during the etching process, under a magnifying glass you can see the traces split and start to curl lengthwise.
Thanks for the link. My printer's not listed, but others from this same manufacturer are.
