electroRF
Hi guys,
I'd love to get your advises on the following challenge.
The developers would like to print log messages into memory.
I'd need to implement a log_print function, which takes as arguments: UINT16 Header_ID, UINT16* pData, UINT16 len.
This function would write the header + Data + time-stamp into memory.
Later, I'll need to implement a parser, which will take this data and will convert it into text, using a known database.
Several challenges exist (perhaps you come up with additionals?)
1. how to overcome a situation where while message A being sent, an interrupt occurs, and the ISR will print a message B?
in the memory, it will look like that:
Start of Msg A ---> Start of Msg B ---> End of Msg B ---> End of Msg A
How could the parser know to differentiate between Message B and Message A?
I'd like to try to use as little overhead bytes as possible, to spare Cycles and Memory Size. (Due to Real-Time, I can't disable
interrupt while sending a message)
2. When should I read the time-stamp? how to overcome a situation where while reading the timestamp, I get an interrupt?
3. if you're aware of additional challenges that need to be taken care of, please share![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you
