Writing to EEPROM
skeeterb
I need help with a bit of code. I use flowcode V4 Demo version and it doesn't generate the code to Read and Write data to and from the EEPROM of a PIC. I need a little help with the little bit of code that I can replace that bit so I can read and write the EEPROM
//EEPROM0: //Macro implementations
char FCD_EEPROM0_EEPROMRead(short addr)
    //This licence of FlowCode does not produce code for this component
    #pragma message EEPROM0: This licence of FlowCode does not produce code for this component
    return (0);
void FCD_EEPROM0_WriteEEPROM(short addr, char data)
I believe flowcode generates BoostC code and so here are my BoostC EEPROM routines.
unsigned char ReadEEPROM(unsigned char address){
    eecon1=0;                   //ensure CFGS=0 and EEPGD=0
    eeadr = address;            //setup address
    eecon1.RD = 1;              //do actual read
    return(eedata);             //and return data
void WriteEEPROM(unsigned char address,unsigned char data){
char SaveInt;
    SaveInt=intcon;             //save interrupt status
    eecon1.WREN = 1;            //enable write to EEPROM
    eeadr = address;            //setup Address
    eedata = data;              //and data
    intcon.GIE=0;               //No interrupts
    eecon2 = 0x55;              //required sequence #1
    eecon2 = 0xaa;              //#2
    eecon1.WR = 1;              //#3 = actual write
    intcon=SaveInt;             //restore interrupts
    while(!pir2.EEIF);          //wait until finished
    eecon1.WREN = 0;            //disable write to EEPROM
I'm not frustrated just a little annoyed. I just needed that little bit of info so I can put information into the EEPROM memory of the chip.
Are my post invisible or something?
Sorry Pommie thanks for your assistance. I noticed the newer reply before I noticed yours. I probably have to tweak the top of the code for reading and writing so it will fit in with the code generated by flowcode. I'm glad I have sourceboost IDE installed along with Flowcode.
Ok now i am getting frustrated. using sourceboost to attempt to build the hex file. It gave me a ton of errors like Unknown Identifier, and Unknown Operand for almost the WHOLE file. I'm attaching a copy of my source code to see if anyone else can figure out wtf is going on with my code.
  • Control..c
The only errors I get are,
C:\Projects\BoostC\Flowcode.c(516:10): error: unknown identifier 'address'
C:\Projects\BoostC\Flowcode.c(516:10): error: invalid operand 'address'
C:\Projects\BoostC\Flowcode.c(516:8): error: failed to generate expression
C:\Projects\BoostC\Flowcode.c(528:10): error: unknown identifier 'address'
C:\Projects\BoostC\Flowcode.c(528:10): error: invalid operand 'address'
C:\Projects\BoostC\Flowcode.c(528:8): error: failed to generate expression
And these are caused by a mismatch in the routines I posted.
char FCD_EEPROM0_EEPROMRead(short [COLOR="red"]addr[/COLOR])
    eeadr = [COLOR="red"]address[/COLOR];            //setup address
void FCD_EEPROM0_WriteEEPROM(short [COLOR="red"]addr[/COLOR], char data)
char SaveInt;
    eeadr = [COLOR="red"]address[/COLOR];            //setup Address
    eecon2 = 0xaa;              //#2
The bits in red have to match so change them all to either addr or address.
char FCD_EEPROM0_EEPROMRead(short [COLOR=red]addr[/COLOR])
    eeadr = [COLOR=red]address[/COLOR];            //setup address
void FCD_EEPROM0_WriteEEPROM(short [COLOR=red]addr[/COLOR], char data)
char SaveInt;
    eeadr = [COLOR=red]address[/COLOR];            //setup Address
    eecon2 = 0xaa;              //#2
I corrected that. I noticed it and fixed it before you made your post. Now I'm getting a bunch of errors like
Warning: Conversion from 'int32' to 'signed int' possible loss of data
Warning: Expression is True
Warning: Conversion from 'signed short' to 'unsigned char' possible loss of data
The first one tracks back to the internals.h file. the others track to the Source file "Control.C"
Well, you can probably get rid of some by changing it to,
char FCD_EEPROM0_EEPROMRead([COLOR="red"]char[/COLOR] addr)
void FCD_EEPROM0_WriteEEPROM([COLOR="red"]char [/COLOR]addr, char data)
char SaveInt;
    eecon2 = 0xaa;              //#2
It's not just that subroutine that gives me the errors. the first error points back to the Internals.h file that I copied from the FCD subdirectory of flowcode. I'm attaching a file I made to show all the errors that it shows in sourceboost ide.
  • Errors..txt
OK, I loaded it up in MPLAB IDE. I found out one of the reasons it was failing. I failed to copy the definitions.h file when I copied the internal.h file to where my source code is. Now it gives me these errors
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 517.11 struct/union required
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 527.13 struct/union required
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 530.11 struct/union required
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 533.11 struct/union required
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 535.17 struct/union required
Error [196] d:\Downloads\miscellaneous\Electronic Files\Control.c; 536.13 struct/union required
I tracked it down to the code that Pommie posted initially. Is there any changes I can make to the code so it will compile using MPLAB?
Here are the lines of code it points to.
Line 517
Line 527
Line 530
Line 533
Line 535
Line 536
What do I need to change?????
You need to go back to the version that compiled but with the code missing and then add the code. I don't use flow code so can't advise how to get it working.
