XC8 pointer behavior!
Pommie
Most Helpful Member
I have converted a program to XC8 and came across the following problem.
This code,
void SeedRand(void){
char *point=0;
    while((int)point<128){
        Seed.bytes.byte3^=*point++;
        if(Seed.bytes.byte3&0x80){
            Seed.word<<=1;
            Seed.word+=1;
        }else
            Seed.word<<=1;
errors on the while line with something about the types being compared aren't the same.
I wondered if it was assuming a rom pointer and so I changed the assignment to *point = &INDF0; to force it to a ram pointer. This warned of a suspicious pointer conversion - volatile to non volatile!!
I have now changed it back and it compiles fine.
Does anyone know how to tell this stupid compiler what kind of pointer you want?
I must say that first impressions of XC8 are not good.
Edit, forgot, this compiled fine on a 18F14K50 and only errored on a 16F1823.
Edit2, just found in the manual that you should never compare pointers to constants. So, how do I write the above code? It's basically reading the first 128 bytes of RAM.
I would personally use variable for the pointer to use..
C:
int x = 0;
char *point=x;
    while( x ++ < 128 ){
            Seed.word<<=1;
            Seed.word+=1;
        }else
            Seed.word<<=1;
I didn't like the pointer cast to a int anyway!!
That code gives a warning: (357) illegal conversion of integer to pointer.
So I tried placing a dummy variable at 0 to point the pointer at,
char dummy @0x00;
But this wont compile even though the section on absolute variables in the manual says it should. (Search absolute variables)
A bit more reading and I find, (Search Absolute Addressing)
In XC8, change absolute object definitions such as the following example:
int scanMode @ 0x200;
to:
int scanMode __at(0x200);
They could have mentioned that in the other help bit.
So, I change it to
char dummy __at(0x00);
And, that won't compile either. It expects a comma and closing bracket!!!
When they can't get the help file correct it makes me wonder about the compiler.
[/winge mode]
What exactly are you trying to do?
If you want to write to a specific memory location, (in the following example 0x20) you write
(*((uint8_t*)(0x20))) = value;
I found several similar issues when using MPLABX..... Once or twice I have tried to compile a piece of code in MPLABX with a load of stress bolted on.... Recompiled in MPLAB IDE 8.x and have had no problems at all.
C:
char x =0;
char*point=0;
   while( x ++<128){
            Seed.word<<=1;
            Seed.word+=1;
       }else
            Seed.word<<=1;
Did you try this.....
PIC16 memory is not flat. It is divided into banks, each bank spans 128 bytes, but only 80 bytes are useable. When you address it through a pointer (FSR) it will go through the entire 128 bytes for each bank.
The useable 80-byte portions of the banks are mapped together into a linear region at address 0x2000 (as I remeber) were they come one after another. So, to get a 256 bytes of continuous memory, you need to start from 0x2000.
