xmodem in hyperterminal
AtomSoft
Im trying to add this function to my pic to download a file into memory. In hyper terminal it acts like the file was send and all is well but in pic there seems to be no data. Here is what i got so far:
void GetFile(char *buff){
    char i;    // Length counter
    unsigned char dat;
    while(!DataRdyUSART()){
        if(Btn01 == 1) //I press button to send first NAK to initiate transfer
            putcUSART(21);//sends NAK aka NCGByte
        Delayms(50); //debounce
    i = 0;
again:
        while(!DataRdyUSART());// Wait for data to be received
        dat = getcUSART();    // Get a character from the USART
                           // and save in the string
        if(dat == 4){  //The End of transmision byte
            putcUSART(21);  //NAK
            dat = getcUSART();
            if(dat == 4) //EOT
                putcUSART(21);//NAK
        } else {
            *buff = dat;
            buff++;
            i++;
            if(i==132){ //After the 132 Bytes come in 0-131
                putcUSART(6); //ACK
                i = 0; //set back to 0
            goto again;
Ill attach the info i have on xmodem also.
You need to add more comments to your code but my first question would be how is buff declared? And my second is why you have the termination code twice?
Ok i commented better i hope:
  With each packet sent...
    The uploader sends:
    1. an SOH byte                             {1 byte}
    2. the packet number                       {1 byte}
    3. the 1's complement of the packet number {1 byte}
    4. the packet                            {128 bytes}
    5. the checksum                            {1 byte}
    The above five things are called the block.
    132 Bytes (0-131)
    unsigned char dat;
            putcUSART(21);//sends NAK aka NCGByte and starts transfer
    i = 0;
again:
            putcUSART(21);  //Send a NAK and wait for another EOT
            while(!DataRdyUSART()); //Wait for data to come in
            dat = getcUSART();  //wait to receive a EOT
            if(dat == 4) // IF ITS A EOT
                putcUSART(21);//SEND NAK
        } else {
            *buff = dat; // The buff is a char data[512];
            buff++;      // Increment Buff Pointer Position
            i++;         // increment i untill 132 which is the first byte of next packet
                putcUSART(6); //ACK
            goto again;
The answer to question 2 is:
"When the uploader sends an EOT byte instead of an SOH byte, the downloader
sends a NAK byte. If the uploader sends another EOT immediately after that,
the downloader sends an ACK byte and the transfer is complete."
The normal way to debug something like this would be to have a simple receive char routine that stores bytes at *buff++ and send a "hello world\n" string from your PC. Put a break point on when it receives a newline and see what you have. You will then know if your pic is receiving the data and if it is putting it in your buffer. If it is, then you move on to the next part.
I just noticed the 50mS delay - this could be a very long time (byte transfered time) if you have a transfer rate greater than 300 baud.
P.S. are you calling the routine with a ram char pointer as the parameter?
Yes its in Ram. Also the delay is only in use when the transfer isnt. Its there to wait and debounce the button press. When i press the button it continues. Maybe i should remove it anyway. Thanks. I know i can get data because... well let me show you some more of the code
void ReadCmds (void){
    char inputstr[100] = {0};
    char badCmd = 1;
    char cmd_01[4] = {"cLed"};
    char cmd_02[4] = {"Menu"};
    char cmd_03[4] = {"File"};
    getUSARTString( inputstr, 4 );
    if(!memcmp(inputstr,cmd_03,4)){
        GetFile(data);
    if(!memcmp(inputstr,cmd_01,4)){
        if (SigPassPort == 1){
            SigPass = 0;
            putrsUSART("\r\nGreen LED OFF!\r\n");
        } else {
            putrsUSART("\r\nGreen LED ON!\r\n");
            SigPass = 1;
        badCmd = 0;
    if(!memcmp(inputstr,cmd_02,5)){
        putrsUSART("\r\n");
        showMenu();
        badCmd = 0;
    if(badCmd == 1)
        putrsUSART("\r\nUnknown Command! Try Again.\r\n");
This is what i use to get commands.
If the delay is only for debounce, could I suggest you do,
        else
However, I know realise I don't understand why you wait for a byte to be available before you check for the button.
Wow thanks i got it working now.
    The uploader sends:
    132 Bytes (0-131)
    unsigned char dat;
sendit:
    while(1){
        if(Btn01 == 1){ //I press button to send first NAK to initiate transfer
            Delayms(10);
            break;
    i = 0;
again:
        putcUSART(6);
        if(dat == 0x72){  //The End of transmision byte
            if(dat == 0x72) // IF ITS A EOT
        } else {
                putcUSART(6); //ACK
            goto again;
What are you actually trying to do?, HyperTerminal and Xmodem seems a completely bizarre method of doing it?. Are you wanting to upload new programming to the PIC, if so a bootloader would be a better idea (and freely available).
Xmodem is intended for modem use (hence the name), with a piece of wire from the PC to the PIC you don't really need to use it.
I wrote Xmodem code years and years ago, in Turbo Pascal under DOS (pre-Windows), for a Packet Radio program I wrote.
Thanks Pommie ... Nigel i want to use this to send my pic some small binary / text files and have it store it on a SD card. I have it so far. Thanks for your interest. I always wanted to know what a bootloader was for. Can you give me a link to more info on that too thanks!
