I am wanting to use a XR-8038 as a signal generator to control an IGBT transistor. I need a positive bias to turn the transistor on and a negative bias to turn the resistor off. I need to do this at 20KHz, 28KHz and 40KHz.
I have the XR-8038 wired to a +/-12V power supply, and get very nice square wave output. The output is 0V to+12V when the ground of the oscilloscope probe is grounded to the common, and -12V to 0V when the probe is grounded to the negative power supply. The circuit is wired according to the Generalized Test Circuit on the datasheet.
The question is, how do I get a square wave that is +12V to -12V, or shift the wave to +6V to -6V?
Thank you for your time.
JT
JT
