Sharpiedeluxe
Hi, I'm really new to diodes, and I'm trying to solve a circuit problem creating a voltage regulator that can operate given four extreme conditions. As far as I have calculated, not all of the conditions can be met at the same time, but I'm not quite sure so that's why I'm asking! I am using a 1N4735 zener diode, with a Zener Voltage of 6.2V, the Pz is 1.0W and I need to find a resistance value given that Vin(min) is 10V and Vin(max) is 14V. the min Load amperage is zero, and the maximum is 70mA.
If you could tell me if I'm doing this right that'd be great.
I calculated the max Amperage based off of the Pz to be
Pz = Vz*Iz , so 1.0W = (6.2V)*Iz , Iz = 161mA
If I was to find the worst case scenario to deal with Power dissipation and stay below 1.0W,
I believe that having 14Vin and 0mA load would require 7.8V drop over a 48ohm resistor
in order to keep the zener voltage. This I assume would be the maximum that R could be.
However in order to keep the Zener Voltage, then the scenario in which there is Vin = 10V and
70mA current on the load means, that 91mA goes through the diode and the V drop over the resistor
would be 3.8V meaning the smallest R could be is 42ohms.
Therefore, I think if I design a circuit in which the Resistance is between 42 and 48 ohms I should be
able to meet the conditions required.
Does this information seem correct or am I missing something critical? Any help would be appreciated.
Thanks so much!
Thanks so much!
