Helllo,
If we have zener diode at reverse biased of rating 5V and connected to 12V the output will be 7V what will be the maximum current that can flow through it?
It depends on the part number of the diode you are using. What is it? The data sheet for the part will tell you its maximum power dissipation limit, and Watt's Law will tell you the maximum current.what will be the max current the diode can withstand
I do not know why Spec talked about a reverse biased LED.
hi spec,Sorry everybody- just ignore my post. I will delete or modify it. That's what you get for not reading the OPs post thoroughly.
spec
PS: if you are just want to generate 7V from 12V there are much better ways.
OK will do. I will get my post #2 sorted firstplease tell how?
i know resistance voltage divider only in DC.
Does cooked gonads cause loss of memory?As I tell others and myself, avoid standing too close to the microwave oven when heating a ready meal.E
Very true.hi 'AG'
If you get your gonads cooked, it would be a blessing to lose your memory.
E
Walters?
