hi guys wutsup! am working on a new project that requires zilog programming, the prototype is all set to go but i'm having difficulty with the program itself, heres the concept:
The prototype works on the idea of an escalator, but with a minor change; it has two infrared sensors (one on the bottom platform, the other in the middle of the escalator)
The sensor in the platform is activated when it detects an object runing a motor for a certain period of time (assuming an upward movement of direction) controlled by the motor driver and a zilog microcontroller.
The escalator will automatically stop after the specified period of time only when the object doesnt pass the second sensor.
When the object passes and is detected by the second sensor, it is activated to run the for an additional period of time (shorter than the first programmed timer) and eventually cause the motor to stop running at the execution of the second timer.
Well, all thats lacking is the program to load to run it, using Zilog. i've set a couple of programs but all failed.
i'd appreciate help from anyone out there
maraming salamat <thanx alot>
