Resource icon
Arduino DCF77 Master Clock with pulse outputs for driving electromechanical slave clocks 2014-09-17
Arduino powered DCF77 Master Clock for driving electromechanical slave clocks
See 4K demo video below showing clock chiming 10 0'clock
Features
Arduino 328 Microprocessor is used to decode Time & date from the DCF77 "Atomic" Clock in Mainflingen near Frankfurt Germany
The DCF77 signal is decoded using the fantastic new DCF77 library written by Udo Klein meaning the clock stays in sync even with a massive amount of noise on the received DCF77 signal http://blog.blinkenlight.net/experiments/dcf77/dcf77-library/
Udo Klein's DCF77 library continually "Auto Tunes" the quartz crystal so in the rare event the signal can't be decoded the clock remains accurate to within 1 sec over many days see his blog here for full details http://blog.blinkenlight.net/
The clock provides the following pulses to drive slave clocks 1 sec alternating, 30 sec, 1 min , 1 hour, 24 hr, 15 min chime of quarter hours, hourly chime of hours
Primary display of time in hours, minutes & seconds are displayed on 1" (26mm) green LED 7 segment displays using a MAX7219 IC.
Secondary 4x20 I2C LCD display is used to display time & date, fast or slow seconds, summer winter correction, display brightness, sync information, signal quality, auto tune'd frequency, auto tuned quartz accuracy and summer winter time mode
The primary and secondary displays are auto dimmed using and LDR and Pulse Width Modulation
The primary and secondary displays are shutdown during daytime and are activated by Passive Infrared detection when someone enters the room
Manually triggered automatic Summer/Winter time correction of 30 second slave clocks
Blue-Tooth link for programming, clock pulse status and PIR adjusting
Auto leap second adjustment of 30 second slave and 1 second slave clocks time and date of leap second can be read via Blue-tooth on your PC or Android mobile or tablet
Recording of fast or slow 1 second slave clock pulses on the LCD display as well as time and date stamping of last fast or slow pulse accessible by Blue-Tooth on your PC or Android mobile or tablet
Below-Details of Blue-tooth output to PC or Android
Circuit details below
Full construction details including many pics and Arduino code can be found on my master Clock page
http://home.btconnect.com/brettoliver1/Master_Clock_MK2/Master_Clock_MK2.htm
Author
oliverb
Views
8,642
First release
Last update
Rating
0.00 star(s) 0 ratings
