Willen
what are they saying?
www.electronics-diy.com/electronic_schematic.php?id=1068
I would not use the word "dissipate".
They say:
0.1watt to 0.2 watt into the amplifier and 5 watts out.
The power gain is 50 to 25. The voltage gain is 7 to 5.
Looks OK to me.
If you over drive the input the output will distort.
The amp is class C so the output is distorted, but I am talking about peak clipping.
On big amplifiers I measured the amount of power in the carrier frequency (100mhz) and at the first harmonics. (200mhz, 300mhz, 400mhz) If the amplifier was over driven the power in the harmonics went up. I know you don't have a way to do that.
If you plot a graph of input power and output power you will find a point where more drive does not get you more power out. Stay away from that point.
Yes. Attenuator will reduce the size of a signal.
They say:
Looks OK to me.
Your posted circuit does not contain any DC bias on the input so I assume it's Class C. Overdriving the input will distort the signal but if it's constant carrier (e.g FM) you just produce more harmonics. If correctly filtered and you don't cook the transistor in the process, it should work fine.
If you need a linear circuit for SSB or AM then your circuit is a no brainer.
You can clamp the input using PIN diodes back to back to prevent overload.
https://www.electro-tech-online.com/custompdfs/2012/07/dioxref.pdf
Is it legal to build a 5W FM band transmitter?
It is legal to build 5 watt FM Tx but it is illegal to transmit.![]()
