madhippiescientist
A little battery does not have much capacity so it will not last long.
It was simply another suggestion, and
those "camera" type batteries, I believe,
are NiMH and have a pretty good AH, for
their size.
We are talking about primary alkaline battery cells that have the same capacity as a charged Ni-MH cell.It was simply another suggestion, and
their size.
That's not my point. They don't use a 2 volt 555.Nearly all solar garden lights use a single 1.25V Ni-Cad cell, a simple cheap voltage stepup circuit and a low voltage cheap solar panel.
Instead if they used three fairly expensive Ni-Cad cells and a much higher voltage solar panel then their cost would be too high.
HELLO. Hey you say that the circuit consumes about 500 micro amps how did you come up with that number? well the led draws 20mA of current right? then how 500 micro ampsNational Semi guarantees that their LMC555 will work with a supply as low as 1.5V.
I made some LED chasers with 74HC4017 ICs that are guaranteed to work when their supply is as low as 2.0V. They all work perfectly when their supply is only 1.4V (but the red LEDs are very dim).
The LED is turned off for most of the time. The Cmos 555 charges the capacitor slowly with an extremely low current then connects the capacitor in series with the battery to blink the LED with maybe 5mA for a moment until the capacitor has drained. Then the LED turns off and the capacitor charges slowly again.HELLO. Hey you say that the circuit consumes about 500 micro amps how did you come up with that number? well the led draws 20mA of current right? then how 500 micro amps
