Hey. Here is my code. Please let me know if this code is right. I have decided to use a 12Mhz crystal instead of the 7.805Mhz.
Just to recap:
I want to generate a 120Khz square wave that will last for 1ms (done by gating the RC2 pin) on RC2 when a switch connected to portD.5 is pressed.
Using the formulaes:
PWM period= [((PR2)+1)*4*Tosc*TMR2 prescalar value] and
PWM duty cycle = (CCPR1L:CCP1CON<5:4>)*Tosc*TMR2 prescalar value,
I decided to use the prescale value =1, this then gave me the following values:
PR2= 24 (0b00011000)
CCPR1L:CCP1CON<5:4> = 50 (0b0000110010)-{10 bit value}
Since CCP1CON<5:4> is the 2 LSb value = "10"--> CCP1CON="0b00101100"
therefore: CCPR1L=8 Msb="0b00001100"
CODE
#include "16F877.h"
#include "DEFS_877.H"
#include "string.h"
#include <stdlib.h>
#include <stdio.h>
#use delay (clock=12000000)
#fuses HS,NOWDT,PROTECT,NOLVP,BROWNOUT,PUT
#use rs232(baud=56000,parity=N,xmit=PIN_C6,rcv=PIN_C7)
set_tris_d(0xff); //setting port d as input
void squarewave (void)
PR2=0b00011000; //set PWM period to 8.3333us
CCPR1L=0b00001100; //sets Duty cycle to 50%
CCP1CON=0b00101100; //Dc=50%
T2CON=0b00000100; //enables timer 2 and sets the prescalar value
set_tris_C(0x00); //output pwm to pin RC2
void main (void)
//just initailises and clears port c initially
set_tris_c(0xFF); //set port c as input
PortC=0; //clear portC
while(1)
if (!input(PIN_D5)) //if switch is closed/pressed
squarewave();
delay_ms(1); //wave on RC2 for a period of 1ms
set_tris_c(0xFF); //sets RC2 as input, so no more
//Pwm present on this pin
Please take a look at my code and let me know if its accurate and correct. Thanks a lot![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Just to recap:
CODE
#include "16F877.h"
#include "string.h"
#include <stdlib.h>
#include <stdio.h>
void main (void)
while(1)
squarewave();
