Coupled Inductors
https://coilcraft.com/smpwrcoupled.cfm
You should not be running the Li cells down to 3V/cell. Very little energy gained past about 3.4V/cell it just wears them out fast. Stack four Li cells and you will have a source voltage you can buck to 12V.I didn't understand what you said.
The voltage range of two Li-Ion batteries in series would be 6V to 8.4V (8.4V when both are fully charged and 6V when both are almost discharged). They can't buck to obtain a 12V output![]()
I can't figure out why you are not comprehending this part... from an earlier post you said:I was rethinking about this design.
The output current will be reduced to 4A at the maximum load, not 6A as the initial idea
I think now I can have a single solution based on a buck-boost topology, right?
My only experience with a buck boost IC was the TPS63000 from Texas, but it doesnt fit the requirements of this design.
Some other recomendations of buck boost ICs now?
Best regards
Using 4 li-ion cells the cost would increase a lot i think. Until now, I just know the "18650" size for li-ion batteries (18650 is a standard format),
I have a doubt about the SEPIC topology. This topology automatically works like a Buck-Boost (VIN can be lower and higher than the output voltage) ??? Or does it need to be "configured" to work just for buck operation or to be "configured' to work just for boost operation ???
Do you know if I can find this kind of inductors (dual inductors on the same core) on Digikey, Farnell, Mouser or others??? Or if I would need to produce them specifically for my design?
have you even looked at the spec for one of these batteries?
https://www.amazon.com/Tenergy-Cyli...9731634&sr=8-1&keywords=18650+lithium+battery
It's about 3.7V @ 2.6A-hr which gives you about 9W-hours per cell.
Yet, you are trying to supply a 12V output at 4A which is 48W. With converter losses, it will be close to 60W of load power.
And you are stuck on the idea you can do this with two of those batteries? You would be drawing about 10A (DC) from the batteries and peaks would be probably 13 - 14A.
Your design can't progress until you get hooked into reality. At MINIIMUM I would recommend you stack four of those cells in series and then buck down to 12V @ 4A. Forget about boosting or buck-boost, you can use a straight buck. You could even use a simple-switcher type which would save you a lot of trouble and development time.
5Ado you have some recommendations of Buck converters capable of 4,5A to 6A output?
I have not followed along for a while.
Have you thought about ORing the input voltage and the battery voltage together then having one PWM in SEPIC mode.
The PWM will get power from the input or the battery, which ever is larger. You will need to choose a diode that has low forward voltage.
