causalitist
anyone know where I can buy a pwm motor speed controller for 0-130vdc that uses a 130vdc input?, or around there... i'd accept 90vdc
got a free treadmill motor 2hp, 17.5A, 130vdc. its already mounted ready to go on a 20 speed lightweight mountain bike. i have it geared for 10mph in 1st gear so peak amps wont be an issue. i have a 24v 1/2hp cim motor, it flys if i advance the timing and give it 36v, but its still too weak for me, and id rather not pull soo many amps.
i have lower voltage controllers, and dont see why i couldnt replace the mosfet(s) with a irfp4668pbf and use a voltage regulator between mosfet load voltage and the pwm part ... or seperate supply for the load/mosfet ...
i have a bunch of irf3710n i can experiment with and burn out before i use the good ones (200v, 9mOhm, 130A).
im only a 2nd year ee student, and of course they wouldnt teach anything that is applicable to an actual circuit.. its all double integrals in cylindrical coordinates inside a capacitor to determine the permitivity of the media... and that classes professor couldnt even tell me how to select a gate resistor for a mosfet!
for this question:
assume my basic 556 timer pwm controller i want to modify can supply a pwm signal with enough amps to run however many parallel mosfets i need
thanks!
for this question:
thanks!
