Hi guys. I'm pretty new into microcontrollers and to get me introduced into this marvelous world I decided to start with some projects about midi language.
The first thing I did was to clone a Olimex JDM PG2C. Tell me if you want the PCB artwork. I made one in Eagle following a photo of the real thing I had found![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
then I tested the programer with the midi merger at **broken link removed**. Things went OK. Everything worked ok so I have to move on.
I had found a project based on a 16C84. First problem. I can't find 16C84s anywhere. I searched for a migration document from 16C84 to 16F84 but no success. the only thing I know is that the 16F has more RAM and some fuses pins inverted but thats all. Both are pin compatible.
What do I have to do for this project to work?
here is the circuit and the program if you want to take a look
Thanks In advance!
Thanks In advance!
