16f vs 18f
Fairly obviously you should NEVER be using 'BTFSS 3,0', utterly pointless, confusing, and non-portable - use the correct mnemonics as you're supposed to (which makes the code 'portable-ish' as well.
Hi Nigel
It comes from your Tutorial 11.1 which converts the NumL and NumH to decimal.
Lb1:
addwf Ones,f
decf Tens,f
btfss 3,0
goto Lb1
How would you change this to work.
I coded as BTFSS STATUS,Z ; or C etc. ( always used uppercase for some reason ...)
<3 asm.
Hi Nigel
Lb1:
addwf Ones,f
decf Tens,f
btfss 3,0
goto Lb1
As the comments in the code explain, that routine was downloaded from the PICList :D
I'm pretty sure I've got a version somewhere that I converted for the 18F series though?, I'll see if I can find it tonight.
OK, took a bit of finding (as it was 2008), but here's TUT3.3 for an 18F2550 - the offending line was simply replaced by BTFSS STATUS, 0 - although it should really be BTFSS STATUS, C
  • tut3_2.asm
I got it sorted out after a battle. I used the BTFSS STATUS,C but it would not register the overflow at the correct time.
The decf also affects the overflow bit C. So I swopped the addwf and decf around and its working now.
Lb1:
decf Tens,f
addwf Ones,f
btfss STATUS,0
goto Lb1
Nice that they have branch instructions. However, nothing beats having a compare, jump if not equal (cjne) like a good ol' 8051. ;)
