16F628A Code Problem
I have followed your earlier comments and added that CBLOC starting address. At that moment , what was important for me was to indicate the OP that he did not have proper format. thus my doubt still remains, whether the include would not take care of start of user definitions? and whether the user still needs to provide the CBLOC start point ( as this is controller dependent).
Try reading the include file, I suspect you're thinking it's far more than it is - which is really just a simple text substitution table.
EDIT:
OK, just been and tried it (after correcting the code to make it assemble), as already stated if you don't give CBLOCK a value it defaults to zero.
Beat me to it again, thats two a row!!
Done the same 'what if' check with include, confirms your findings.:)
The cblock command does not start at the free memory as would be sensible. Instead it starts at zero and so can cause problems with people that don't realise this. I posted the comment so the OP would not suffer this problem. This was posted as a "just in case" and somehow became the focus of this thread. Why is it that people can't just accept statements as just statements.
Personally, I'm getting sick of people (actually person) picking me up on everything I say.
I state something correct,
I'm asked for an explanation,
I explain,
Some totally irrelevant fact is then posted,
WTF?
I explain,
WTF?
Thanks, Mike, Ericgibbs and Nigel.
But don't you feel Microchip could well accommodate such facility, as we define a chip and also indicate the include file.
The MPLAB has been set to the said processor. I don,t find any reason why the compiler can't have an algorithm built in to start such CBLOC at the appropriate default point depending on chip selected, and give a message, in case the length of message exceeds the register limits.
Perhaps, if Microchip could include such facility, it would make the programmer's life comfortable.
I don't really see as it would, it's hardly difficult to use the command properly, if you even use it at all - because there's no actual need to if you don't want.
I want to specify things to go where I want them to, which may not be the same place as you do.
Assembler is the 'lowest level' method of programming, it gives you total control over everything possible - if you want it to do things for you, perhaps you should be looking at a high level language?.
Hi again
; SETUP THE I/O PORTS ETC
BSF STATUS,RP0
MOVLW 0x01
MOVWF TRISA
BCF STATUS,RP0
CLRF PORTA
ORG 0x00
I have a question. What does RP0 mean? What is wrong with 0x05? Also why is the org statement there? Most programs that I see on the internet, has the org statement on the top just before the general registers. Will it have any effect, when I leave out the org statement?
Hi again
it is the same. It is bit"5" of the STATUS register and is called RP0, When a specific name has been given, why to use the bit number? see issues related to bank selection in the datasheet of 18F628A
0x05 is pretty meaningless, why not use it's name RP0?, it's a specific status bit designation.
Don't leave it out - move it to where it should be (before the BSF), the code won't assemble as it is.
I suggest you have a quick look at my tutorial codes, which have all the required parts in place.
Hi
Hopefully this is the last. I just want to know, is the code right as it is now? I have changed and corrected the errors, according to the posts.
; INCLUDE PIC16F628A
	LIST 		P=16F628A
	INCLUDE 	<P16F628A.INC>
	__CONFIG	_BODEN_OFF&_CP_OFF&_PWRTE_OFF&_WDT_OFF&_XT_OSC&_LVP_OFF&_MCLRE_OFF
	ERRORLEVEL	-302
	ERRORLEVEL	-203
; GENERAL REGISTERS
	CBLOCK  0x20
COUNT1
COUNT2
	ENDC
; PROGRAM START
ORG        0x00
; DISABLE COMPARATORS
MOVLW    0x07
MOVWF    CMCON
	BSF		STATUS,RP0
	MOVLW	b'1'
	MOVWF	TRISA
	BCF		STATUS,RP0
	CLRF	PORTA
; START
START
	BTFSS	PORTA,0
	GOTO	START
	BSF		PORTA,1
	CALL	DELAY
	BCF		PORTA,1
	CALL	DELAY
	GOTO	START
; SUBROUTINES
DELAY	DECFSZ	COUNT1,F
		GOTO	DELAY
		DECFSZ	COUNT2,F
		GOTO	DELAY
	RETURN
	END
I also checked your LED Flash tutorial. It explains quite a lot more than in the tutorial I used. It's late now, so I will check it out in detail tommorow after school. :D
It works for me.
Unzip this attachment, its an *.avi file, play it with Windows media player.:)
  • led1.zip
