20 Watt Power Amplifier
ElectroMaster
Administrator
This IC chip was designed specifically for use in power boosting applications in automobiles. It is self protecting against short circuits and thermal problems.In the bridge configuration shown it will deliver 20 watts of power into a 2 ohm speaker operating at 14.4 volts.
dustinpruente said:
is there a way to step up the output, i would like to get it to around 250 watts
no way!!!
you cant get any more power on that IC
its characteristic is the same as LM2005T
20 watts bridge connection
for a 250 watts, you can only attain this power by using higher supply voltage such as +/-35 volts
Oh I think we can squeeze 250 watts out of that circuit.... say IHF ratings at 1kc. for 1 microsecond.
URGENT :Do I use it for 5 watt RMS Power Amp
can I use this circuit for 5 watt RMS Power audio Amplifier with low distortion.....if yes plz reply the require changes.....it's urgent for me....
plz
urgently
The TDA2005 isn't a hi-fi amp, it is a car radio amp. Its distortion is typically 0.3% (1% max) as a 2-channel stereo amp, up to 6W RMS per channel into 2 ohm speakers and a 14.4V supply.
If you want very low distortion then use a hi-fi amp IC. They need a supply voltage much higher than a car battery and drive 8 ohm speakers.
Baaaaaaaaaaaaaaaaaaaaaaaaaaaaaa......
hello guys i need a 200 watt audio amplifier for my major project,
i need a stable and working ckt which looks a big project plz try to help me
Here is the list of ic's. little old but ok.
Now new development r class D based & not suitable for newbies.
  • audio.pdf
How far would I need to drive to buy old low power Russian amplifier ICs?? About 20,000km?
High End Audio Amplifier
Is there anyone interest with creating new Hi-End Audio Amplifier thread?
I've initiate it, but I've no access to do it.
I'll help to start it with my 7th version K32 that been fixed in dec2005.
And also analyze old halcro schematic.
