dannix said:mvs sarma, We have a 230v supply here in the UK so I can not supply it with 110v, the primary windings are already wired in series.
THere is little information with the dc convertor, there is some pots for output voltage adj and battery low voltage disconnect setting,.................
It should be 7815 and not 7915. 79 series are negative regulators.dannix said:I was hoping pwm would have worked for that but it didn't. I will try and get the voltage down one way or another prob a 7915
mvs sarma said:It should be 7815 and not 7915. 79 series are negative regulators.
Change the transformer and turn o , you would succeed.dannix said:Right I have got a 9vac out transformer 100va this will give me the 10a max i require with a little extra (not as much as I would like but wont't be max'ed out much)
so by my calc thats 9vrms * 1.414 = 12.73
12.73 - 1.4 diode v drop = 11.33vdc at max current
in reality the transformer output voltage will be higher at the intended lighter loads, I guess about 10vac, which is 12.7vdc.
In both cases the DC-DC convertor will buck / boost it!
I will keep the 15vac 300va transformer for a desktop PSU, any recomended schematics that can take 15vac in and give variable 3-12vdc (give or take) out?
dannix said:Driver300, your right it could work, but I only just got this transformer, don't really want to rip it to bits
Diver300 said:Single core flex might be easier to wind. You need to push the wire through the toroid once for each turn.
dannix said:Good news, I replaced the 15vac transformer for a 9vac transformer and it is now working a treat, thank you everyone for your assistance, most appreciated!
