grim
240v won't kill you. just ask the birds sitting on the overhead cables
that's the everyday example of an earth free circuit.
the important bit is '240v with referance to'
in the case of birds on a wire, in referance to nothing at all, so they are fine
in a normal home supply live is 240v in referance to earth and Neutral
an isolation transformer means the isolated live is only dangerous if you touch the isolated neutral - referance to earth has been removed.
a thick rubber mat means you are not earthed, so can touch a wire that is at 240v above earth - in this case you are the bird on the wire
nothing will help you if you touch live and neutral at the same time, hence hand in pocket.
and an earth leakage breaker is not much use, if you use an isolation transformer
persoanlly I have always used an isolation trany in test labs, and i know as long as i only touch one terminal, i am ok.
