CHELLIE
Hi Everyone
I have a Question, I think it can be done, but i am going to ask the pros here first
Ok here is what I have, I have a 24volt dc solar system, the 12vdc batteries are wired in series for 24 volts DC, my solar Panels are 24 volts and my solar regulator is 24volts, that part should be OK
Now what i want to do is run my 12vdc to 115vac 3500 Watt /7000 Watt max. inverter off my 24v batteries, i am looking at a 24vdc to 12vdc 60 amp converter, and was wondering if i can wire 2- 60amp 24vdc to 12vdc converters in Parallel, for 120amps 12vdc to feed my 12vdc to 115vac inverter ? thank you for your time, Chellie
