Hi, I like to build a remote application that use 315Mhz Receiver with coin size (CR2032) 3V battery power, the chalenge is have to be very small size, 5cm x 2cm, and battery power.
Question:
1. What is the typical/minimum current consumption of a 315Mhz receiver?
Which operate on 3V? So I can check how long the battery can last.
2. If the anttenna is insert to ground ,I mean outdoor, about one inch of bare wire under soil, will it improve or reduce the receiver range?
The remote range is target to be 20m, I think can achieve by increase TX power, if receiver signal reception is poor.
Thank you,
Question:
Thank you,
