I want help creating a serial in parallel out shift register. I came up with this schematic(attached) but I think it's not going to work since I think it won't store all 4 bits and then transmit them but instead transmit a bit or two as soon as they arrive and the others during the next cycle .I've used flip flops without CE and CLR to keep things simple. It's supposed to receive 4 bits in serial and give 4 bits in parallel. I'm using two 4Mhz clocks, one for a PISO shift register and another one for this shift register(they are on two different platforms) I would appreciate if you could give a proper working serial in parallel out shift register schematic preferably without CE, CLR, reset, preset if
possible.
I'm a complete beginner in electronics as you can see................
possible.
