philba said:I think the 2016 is a high side driver (check me on that, it's not totally clear to me from the datasheet) so you will need to use the "inverted" output of the '154.
hi Phil,
Checking the NTE2016 data dosn't say its a high side driver.
On the point about how this worked before electronics - I think there has to be an elegant solution there.
I feel sure that the cams produced the 'code' for the 8 lamps.
Drop the inverters. There are 16 output combinations from the cam switches.
Regarding the number of switches, I'm wondering if the metal frame is the common of the 4 contact sets???
Look at my earlier EXAMP.pdf, it shows 4 switches driving the 8 lamps.
