It was still a good idea and I have used your voltage regulator approach in a new version of the pump controller in post #19. Luckily I found a variable voltage very low drop out regulator (around 300mV) which should be fine.Hi spec,
You make a valid point about the high dropout voltage of the LM317. I did not think about the voltage drop so Your PWM solution is much better than my suggestion. I don't know of any variable LDO regulators and even an LDO regulator would have some volt drop.
Hmm, you have got me thinking now about how those timers workI think your new circuit (Post #17) should work using the timer modules linked to in post #1 providing the relay is energised when power is applied and de energise after the delay period. (I think this will be the way they work.)
Yes, I have done various circuits, some with speed controlled override, but but I figured that the purge function would be carried out at full pump speed.The way you have connected the override button (S5) would run the motor at full speed when pressed. If Cribey wants the speed control to function with the override button then you could add a fifth diode to the diode OR gate and connect the push button between +12 and the anode of the diode. Another way would be to connect the override button between emitter and collector of Q3. I don't know if PWM would be better than a variable voltage source at starting the motor at low speed settings.
It has a very low dropout voltage. It is a 3A part which is £1.40 from Digikey. There are also 1.5A (£1.67), 5A (£5.52), and 7.5A (£11.40) parts, but the IO differential is only 26V on the whole family.Edit.
spec I see you have found a variable LDO regulator with a dropout voltage that may be good enough for Cribey's application.
I am always messing with power supplies and keep a library of spec sheets for interesting/useful parts- bit of an anorak really.(It would be interesting to now what it was being used for.)
spec
