I’m using NE555 in ASTABLE mode. I want to turn an LED on & off continuously with these requirements.
ON time 3 Seconds
OFF time 1 Second
(LED will turn ON 3S & OFF in 1S)
These are the formulas I used to calculate my R1 & R2. C1 I used 10uF.
Mark time (output high): Tm = 0.7 × (R1 + R2) × C1
Space time (output low): Ts = 0.7 × R2 × C1
After calculating I got this values.
R1=285 Kohms
R2=142 Kohms
Questions
1) Is my values correct?
The duty cycle is the proportion of the complete cycle for which the output is high (the mark time).
The duty cycle formula is given by D = Tm / (Tm+Ts).
2) What is the different between Duty cycle and the Mark time? These both are depending on ON time?
3) What is the meaning of 90% duty cycle? Is that the mark time is ON for 90% & the other 10% is space time?
4) In my earlier example the duty cycle is 0.75.Is that means the mark time is 0.75? But I calculate the Mark time as 3 seconds.
5) If I want to turn ON an LED bulb for a calculated time and OFF for another time do I need to consider about Duty Cycle? Or can I ignore that.
ON time 3 Seconds
OFF time 1 Second
R1=285 Kohms
R2=142 Kohms
Questions
