What is the VA rating of your transformer? If it's too low the core will saturate and the output voltage will be low too.
R6 R7 should be 1R
Even with R6,7 at zero ohm, the primary of the transformer is getting less than 10v. The circuit is completley unworkable.
thanx guys what should i alter in the design to make it perfect for about 100watts and please tell me what values of resistors should i use at the base of tip122 (output of opamps) and r the emitter resistors of tip122 correct ??
there is no reason to have any resistors.
I think almost everyone else here would disagree with you![]()
so the emitter resistors are there to keep the magic smoke in?
please explain
They are - essentially for current limiting - however also for current sharing when you parallel the devices (and for 100W I'd really like to see two pairs of TIP35's). But base resistors are essential as well.
Personally I'd also replace the TIP122's with PNP's, to give much better base drive to the TIP35's.
there's only one transistor.
now granted you could make the argument that the resistors are there to combat flux walking.. but i'd expect the resistance of the transformer to be sufficient
The output is a square-wave at a voltage that is reduced by all the losses.
What do you have that works when fed a square-wave with a voltage that is too low?
