R raviram87 New Member Apr 7, 2008 #1 is it possible to configure the simple 555 timer as an A/D converter ? i came across this on one of the websites.. how can this be done? are they talking about the schmitt trigger here?
Nigel Goodwin Super Moderator Most Helpful Member Apr 7, 2008 #2 Almost certainly not, usually it's used for converting a resistance (as in a joystick) to a frequency - this is how the joystick ports in a PC work. You can use a voltage to modify the output of a 555, but it's a far more limited range.
R raviram87 New Member Apr 7, 2008 #3 i wonder whether it is similar to a voltage to frequency converter ?
Nigel Goodwin Super Moderator Most Helpful Member Apr 7, 2008 #4 raviram87 said: i wonder whether it is similar to a voltage to frequency converter ? Click to expand... Yes it is, just limited in range though and not linear.
crutschow Well-Known Member Most Helpful Member Apr 7, 2008 #5 raviram87 said: i wonder whether it is similar to a voltage to frequency converter ? Click to expand... Without seeing the circuit, I would guess yes.
