I have seen the rule on motors, but what about arc welding? they use a very high current (140 amp) but a voltage of 1.5 volt I guess, so high current lo voltage is possible.
To Aiden1015, under no load the electric motor eats more current while it starts, later the current consumption is lower.
Otherwise, the current consumption will increase proportionaly with the load that your motor is driving. So make sure your batteries provide enough current to meet the requeriments under maximum load.
You don't have anything else to do with the motor current
Instead use an adecuate way to control the given voltage to the motor, to select the desired operating speed
Correct me if I'm wrong, but the torque of an electric engine remains constant at any RPM, opposite to internal-combustion engines - att: discovery channel
