'O' is for Orders (powers/indices/exponents); following only BODMAS strictly actually gets the answer of 9.B O D M A S
B Brackets ( )
O Of
D Division /
M Multiplication x
A Addition +
S Subtraction -
so the answer is 1
B Brackets ( )
O Of
D Division /
M Multiplication x
A Addition +
S Subtraction -
so the answer is 1
...to me it's about as interesting as a discussion on proving which faith is correct
I think you've added some extra brackets up there... You have done a substitution based on the assumption that the implicit has the higher precedence.
You are of course correct in that statement. What I was meaning by my related comment was that without an accepted rule/convention for precedence it cannot be objectively argued either way.Well nobody's forcing you to participate![]()
If that's the accepted practice, then you know the correct answer to the original question & there's no debate to be had.The implicit does have the higher precedence.
B O D M A S
B Brackets ( )
O Of
D Division /
M Multiplication x
A Addition +
S Subtraction -
so the answer is 1
6÷2(1+2) when you do the distributive property: 6 / (2 + 4), you do end up with 1. Even with parenthesis first, you end up with 1.
The only problem that comes in is when we try to use the same equation in both calculators...we have to know how they will handle it. BTW the TI89 reformats the equation into 6/2*(1+2) before giving the result. That at least tells us how it decided to handle it.
The TI85 programmer didnt realize that there could be an interpretation difference there.
Parenthesis first gives rise to the 1 answer.
6/a(1+2), 6/x(1+2), 6/A(1+2), 6/A (1+2) - Wolfram|Alpha
If it is not a bug, I would like to know the logic behind those results.
I can't believe this has gone to four pages
It's a question which is deliberately written incorrectly - if it's written correctly there's no problem at all.
