I thought I hadEfficiently reduce it to it's essential elements?
Well, not large. Apart from any components on a heatsink the remainder could fit in a matchbox.The electronic version is so large and complex.
I thought I'd covered all the requirements. What does the mech reg do that the electronic version doesn't?the 50 yr old mechanical regulator performs more functions, and in a smaller space.
I'm not aware of any. You can use software such as Eagle to do auto-routing of connections, but it still needs manual input for component placement.Is there a computer program or software that will arrange the components and connections in the smallest possible space?
All resistors except R1 and R11 could be 1/8W. R1 would be 10W or more. R11 would be 30W or more, surface mount. I haven't yet investigated which FETs would be best (right specs, easily sourced). Who is your preferred supplier?The schematic shows the resister values and transistor models, but what current should they be rated for?
Because in my limited searching I was unable to find an axial 0.01 Ohm (or lower) resistor, able to handle 10A or so, at a sensible priceWhy is R11 surface mount?
