Sorry, i mean connecting the 193 outputs directly to the 165 inputs. No hardwiring
Sorry, I dont understand why i need a latch and 8 count detector circuit? is it to drive the clock because i was thinking of using a astable pulsing at very high freq for the clock.
thanks
Basically i want to detect 5 spikes from a pulse generator, hence 5 counts and when the counter counters upto 5, sends 5 to the shift reg. the shift reg will transmit the 5 serially, than after some more circuit transmits the signal wirelessly. upon retreiving the 5, a SIPO shift register will convert the 5 back to parallel to display on a display.
if i was using a regular clock at both ends than the remote sipo will be in sync
i'm a bit confuse on this one...how would I the three 1's as a sync pulse?
in your previous post you mentioned a 8 count detection circuit, should I use the 193 again and jam the inputs to output 8?
IF its always a '5' then all you need is a sync type pulse at the remote to know its a '5', you dont have to transmit a '5'.How would I tell the remote that 5 counts have taken place if all the 8 pins are HIGH?
And to create the sync type pulse, I'll need a monostable and gates at the remote end
