Ricardoco said:I am building the P16PRO microcontroler programmer and i need a 74lso4 all i can find in my workshop is a 74ls05 ive looked at the data sheets but still cant tell if i can use it.. any help would be most helpfull and i will think you are great!!![]()
well its the same pin out and it is open collector so i assume that it will be ok...It needs to be an open-collector buffer chip, inverting or not doesn't matter, you can set the software accordingly.
Ricardoco said:well its the same pin out and it is open collector so i assume that it will be ok...It needs to be an open-collector buffer chip, inverting or not doesn't matter, you can set the software accordingly.
LOLAssumption is the mother of all fuckups
