8051 Atmel programming in C- Need help for one example
Yes, I fix that in the meantime...
I need this
TH0=0x3C;   TL0=0xAF;
In that case I have 1 s. But problem is he put on display all numbers in 1 second . I need 1s per number . Not all..
So that is problem now..
I tried with interrupt which you posted but dont work...
Thank you for that but Time TH0=0x3C; TL0=0xAF; is good for 1 s.
Problem is where put the (I think) interrupt after every number in string ...Because that is possible way to solving this problem. I dont know how to put that in code...
I can not allow to pass through all the numbers in one second.
I working in KEiL softwer micro vision... When I debuging softwer trow me on display one kel maket which consisting of diodes. So that is way how I tested
if ( (when counter decreased by one, counter is equal to zero) then decrease counter by one )
So if counter was 1.... "a-1;" is executed bu then counter is decreased again so counter = -1
If counter = 2.... You'll miss it..
BTW... my code does work!!! I tried it here before I sent it!!
Hi, I solved problem with displaying number per second. But now I have problem with displaying numbers with four string...
He always recognizing only one string in interrupt rutin. Probably I need something between strings in interrupt rutine .. But I dont know what..
So program check only one string, another doesnt exist. He must check all string but I dont know how
NEED HELP
#include <reg51.h>
#include <math.h>
typedef unsigned char byte;
byte a[16]={1,22,31,4,5,6,7,8,23,3,10,30,73,40,55,93};
byte b[16]={3,14,7,13,17,19,97,1,12,128,127,124,123,122,33,21};
byte c[16]={9,15,4,13,41,49,57,18,74,3,39,59,112,100,91};
byte d[16]={33,58,68,66,21,19,97,1,14,222,56,12,3,9,15,11};
sbit switcher=P0^0;
byte i=0;
byte counter;
byte xdata display _at_ 0x8001;
void Inic(void) {
   EA=1;
   ET0=1;
   TMOD=0x01;
   TH0=0xC3;
   TL0=0x50;
   TR0=1;
   counter=0;
   i=0;
void timer0 (void) interrupt 1 using 2 {
   TH0=0xC3;
   TL0=0x50;
if((++counter==0)) {    counter=20;
   if(switcher) {
   if(!(a[i]%3) )
     display = a[i];
     i++;
     if(i==16) i=0;
      if(!(b[i]%3) )
       display = b[i];
     i++;
     if(i==16) i=0;
       if(!(c[i]%3) )
       display = c[i];
     i++;
     if(i==16) i=0;
       if(!(d[i]%3) )
       display = d[i];
     i++;
     if(i==16) i=0;
   TR0=0;
void main(void) {
   Inic();
   while(1){TR0=1;}
Your code must be as this
#include <reg51.h>
#include <math.h>
byte a[3]= {2,1,8};
byte counter, frequency,displ;
int i=0;
sbit switcher=P0^0;
void Inic(void)
ET0=1;
TMOD=1;
TH0=0x3C;
TL0=0xB0;
TR0=1;
counter=1;
frequency=0;
void timer0(void) interrupt 1 using 2
TR0=0;
TH0=0x3C;
TL0=0xB0;
TR0=1;
if(switcher)
if(!(--counter))
counter=frequency;
display=displ;
void main(void)
Inic();
EA=1; // It is good to enable goble interrupt in the main
while(1)
if(switcher)
for (i=0;i<3;i++)
if((a)/2) // " a/2 what is this? You con't pass an array to it,
//pass only array elements as this a
//if you use (a/2) compiler gives Error C:193
//"Bad Operand Type"?"
//This error results when an expression uses
//illegal operand types with the given operator.
//Examples of invalid expressions are
//bit * bit, ptr + ptr, or ptr * anything.
displ=a;
frequency=20;
  • test.c
