1. I've got a bunch of capacitors with no uf rating or voltage marked on them, however, they're marked with [number]J (perhaps the J is for joules?). I need help identifying them, as I've got three main groups:
a) 6 of these about 1"x3/4"x1/2" dimensions, marked "683J [what looks like an 's' in the middle of an ellipse]" then on the next line "800 A05"
b) around 10 of these that look smaller than (a) but otherwise are almost identical, marked "333J (S)" (new line) "400 *L"
c) what I think is a red capacitor 1/2" square and about 2/3" thick marked "2A374J"
Are the 'J' ratings voltages or capacitances or something else?
2. I don't know what these parts are, but I've got a bunch of various colored components that look basically like square plastic boxes with leads coming out of one end. I don't know much about electronics, so I don't even know what type of part these could be, however, a lot of them are marked:
a) Red one marked 9201-05-20 (newline) COTO-8837
b) Black one marked "Omniron Japan (newline) G2VN-234PH-US (newline) 12VDC" on top, "2312D9" on one side, and "Contact USA 120VAC (newline) 1.5A 30VDC (newline) Coil: 12VDC" on the opposing side
c) Small white one marked "1J63" on top
d) Grey one marked 3u2J50 on top, "9737 (newline) EVOX (newline) MMK" on the side
3. How do I place capacitors in such a way that their voltages are added (eg.- if I have 2 50V caps, should I put them in series or parallel for 100V)? Also, is there any way to place the capacitors together and increase voltage without increasing capacitance (eg.- putting 2 50V 1uf capacitors so that I get 1uf 100V, instead of 2uf 100V)? Also, if, for example, I have 3 50V capacitors connected in series/parallel (whichever increases voltage), could they be charged with a 50V power supply and yet when discharged together output 150V?
4. I've got an inductor that has 8 loops wrapped around this (estimating here) 3/16" ferrite thing, could I use this as an inductor for an FM radio? Also, what's the difference between FM and AM radio?
5. What's the formula for the output frequency of a 555 timer (in Hz)?
6. Where can I buy cheap, high voltage (5-15kV) capacitors? I think I'm going to need them to make a tesla coil or coilgun (or maybe a tesla coil powered coilgun :twisted:[/b})
7. What are some of the most commonly used ICs and what do they do (the next time I order parts I'm going to try to stock up because not having the right IC is really annoying)?
Thanks in advance for whatever help you decide to give me![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
