jbelectric777
Good Morning: Just a few basic questions, all feedback is appreciated:
1) Is it better to switch +V or -0V, I ask because some shematics switch + and some switch -0 in my field we always and only switch the hot leg so I am slowly learning in electronics either can be switched via , transistors, IC's etc.
2) If time = RXC does that calculation reflect the 2/3 trigger voltage for a 555 timer or transistor or does that calculation need to be figured different. For example if my source is 9V then my trigger is 2/3 (6V) would I find R & C by using the 9V value or the 6V value this way i could calculate exactly what size resistor I should use for a trigger pulse of 1.0s based on T=RXC and using a 1000uf capacitor is it a 10K resistor for 1 second ?
3) Is there a set trigger for a transistor if I just want it to turn on and off, I learned there are other types of electronic switching devices I could use but a standard on / off switching what is best to use and what is the trigger value. (Example: I dont want my IC's to see the current draw of a very small miniture relay so I want to switch another source from either a transistor or other device but I want it to trigger not amplify) Thanks in advance. Jim
