Ratch,
I don't know what to say here. Maybe you are spouting all this small stuff now to cover your blunder that you completely missed the mark. You argued that this subject is easy to figure out, after I mentioned that I think that it takes a lot of time to understand the theories and data. Yet, you don't get the most important point about GH which relates to infrared absorption.
The bottom line here is not these details. The bottom line is that you have totally misrepresented the GH effect. You argued that CO2 cant possibly matter because small amounts of CO2 can't create a significantly different insulation effect. The GH worry is based on the principle that small amounts of green-house gas most certainly have a significant effect. Their effect is to create the wonderful earth climate we have. Without that effect the earth surface would be very much cooler. Some GH effect is definitely a good thing. Insulation of CO2 does not explain the effect but infrared absorption of CO2 does.
Yes, and not just infrared. All electromagnetic radiation including radar frequencies, like microwaves.
Yes, this one is correct. Did you think I didn't know that? Is it in any way relevant to the issue here? Anyway, correct for whatever it is worth to you.
Well, that is not the way GH gas is described. The conventional description is that the visible light is first absorbed by the planetary mass and converted into infrared, which gets trapped by the CO2's insulation properties. You say that CO2 absorbs EM radiation directly. OK, then it would be a shield to incoming EM radiation from the Sun, and it helps cool down the Earth. If CO2 can absorb heat, doesn't that make it an insulator, too? After all, it prevents heat from transferring as fast as it normally would.
OMG Ratch. I didn't say CO2 absorbs EM radiation directly from the sun. Certainly, it can, but that's not the concern. The primary energy from the sun is not in the infrared (> 1000 nm wavelength) initially incoming. Visible light and some infrared (< 1000 nm wavelength) is absorbed at the surface and converted to infrared light (> 1000 nm) in a down-conversion process. The re-radiation of infrared back would go back to space, and does go back to space. However, green-house gases absorb some of the infrared that is trying to go back to space, which then heats the atmosphere. This is the basic description I've heard. Insulation is not the prime consideration here. Heat conduction is not how the earth cools and I don't see how GH people would ever argue that small amounts of CO2 would significantly change the insulation due to air. It is primarily a black-body radiation cooling which depends on absolute temperature. If more heat is trapped in the atmosphere (through infrared absorption), the equilibrium requires the temperature of the earth go up so that black-body radiation can match the net incoming absorbed radiation.
Definition of heat: A measure of the kinetic energy of the molecules of a mass. Heat can transfer, but the transfer process itself is not heat.
This is not correct. In thermodynamics, the measure of the kinetic energy of the molecules of a mass is called "internal energy". Heat is the amount of energy transferred.
Yes, heat transfer is dependent on a temperature differential.
Not quite right here too. Blackbody radiation does not depend on temperature differential, it is dependent on absolute temperature. Hotter objects radiate more energy and at higher frequency. If more photons are absorbed in the atmosphere, then the earth needs so be hotter so that black-body radiation can maintain an equilibrium.
