Volatile... I
If you create an array ..ie.. char text[] ={"hello"} There is a good chance the compiler will compile the array as a constant (in code memory). To stop that from happening you can make the array volatile.
Yes MrT! But when you initialize an array with text.. The compiler optimizes the array to a constant!! the only way to override is to make it volatile to stop this from happening... OR!!! as Jason pointed out... Leave it as a constant and cast the text when you use it!!!
Code:LCDStr(char *string) { while(*string != 0) { LCDChar(*string++); } } // TEST CALL char Variable[13] = "Hello AGCB!\0"; LCDStr(Variable); //or LCDStr((char *)"Hello AGCB!\0");
while(*string != 0)
LCDChar(*string++);
while(*string != 0)
LCDChar(*string++);
LCDStr((char *)text);
/////////////////////////////More LCD ///////////////////////////////////////
//Sat AM Feb 22 added Line and Column GOTO
#include <p18F43k20.h>
#pragma config FOSC=INTIO67,BOREN=OFF,PWRT=ON,WDTEN=OFF,PBADEN=OFF,STVREN=OFF,LVP=OFF
//////////// Defines ////////////////////////////////////////////////////////
// The lower 4 bits of this port will be used
#define LCD_DATA LATD
#define LCD_EN LATDbits.LATD7
#define LCD_RS LATDbits.LATD4
#define TRIS_LCD_DATA TRISD
#define TRIS_LCD_EN TRISDbits.TRISD7
#define TRIS_LCD_RS TRISDbits.TRISD4
#define TRIS_LCD_PWR TRISEbits.TRISE2 //RE2 is for LCD power control through MOSFET
// Commands for Hitachi LCD
#define CLEAR_DISPLAY 0x01
#define FOUR_BIT 0b00101111 /* 4-bit Interface */
#define EIGHT_BIT 0b00111111 /* 8-bit Interface */
#define LINE_5X7 0b00110011 /* 5x7 characters, single line */
#define LINE_5X10 0b00110111 /* 5x10 characters */
#define LINES_5X7 0b00111011 /* 5x7 characters, multiple line */
#define DISPLAY_ON 0b00001111 /* Display on */
#define DISPLAY_OFF 0b00001011 /* Display off */
#define CURSOR_ON 0b00001111 /* Cursor on */
#define CURSOR_OFF 0b00001101 /* Cursor off */
#define BLINK_ON 0b00001111 /* Cursor Blink */
#define BLINK_OFF 0b00001110 /* Cursor No Blink */
#define UNDERLINE_ON 0b00001111
#define UNDERLINE_OFF 0b00001101
#define INCREMENT 0b00000111 /* Entry mode increment */
#define DECREMENT 0b00000101 /* Entry mode decrement */
#define SHIFT_ON 0b00000111 /* Display shift on */
#define SHIFT_OFF 0b00000110 /* Display shift off */
#define PulseEnable { LCD_EN = 1; Nop(); LCD_EN = 0; }
// Required prototypes.. each function needs to be declared
// if called BEFORE definition.
void LCDInit(void);
void LCDCmd(unsigned char); //RS is 0 for commands
void LCDChar(unsigned char); //RS is 1 for characters
void LCD_GOTO(unsigned char,unsigned char); //Sets position, line and column
void Delay5ms(void);
void Delay15ms(void);
void Delay100ms(void); //100 ms delay
void LCDStr(char *string);
char SimpleHello[13] = "Hello AGCB!\0";
unsigned char text1[] = {"Hello"}; ?????????????????
//////////////////////////// MAIN funtion ////////////////////////////////////
void main (void)
int index = 0;
OSCCON = 0xD0; /* Set internal oscillator at 4 Mhz */
ADCON0 = 0x00; /* Disable internal ADC */
TRISEbits.RE2 = 0; //turns on power to LCD via MOSFET ????????????????
TRISD = 0; //Make all bits on the Port B (LCD) output bits.
PORTD = 0; //Reset the LCD bits to 0
Delay15ms();
LCDInit();
LCDStr(SimpleHello);
while(1);
void Delay5ms(void) {
Delay1KTCYx(10); // Delay of 5ms
// Cycles = (TimeDelay * Fosc) / 4
// Cycles = (5ms * 8MHz) / 4
// Cycles = 10,000
return;
void Delay15ms(void) {
Delay1KTCYx(30); // Delay of 15ms
// Cycles = (15ms * 8MHz) / 4
// Cycles = 30,000
return;
Delay1KTCYx(100); //delay 100 ms
void LCDInit(void) {
PORTEbits.RE2 = 1; //turn on LCD power
Delay100ms(); //100 ms delay to power up LCD
// Set port directions
TRIS_LCD_DATA &= 0xf0; // Clear lower 4 bits
TRIS_LCD_EN = 0;
TRIS_LCD_RS = 0;
//LCDCmd(FOUR_BIT); // Nigel's code sends this before the next command?
LCDCmd(FOUR_BIT & LINES_5X7);
LCDCmd(INCREMENT & SHIFT_OFF);
LCDCmd(DISPLAY_ON & BLINK_OFF & UNDERLINE_OFF);
LCDCmd(CLEAR_DISPLAY);
Delay15ms();
void LCDCmd(unsigned char c) {
LCD_RS = 0;
LCD_DATA &= 0xf0;
LCD_DATA |= (c >> 4);
PulseEnable;
LCD_DATA &= 0xf0;
LCD_DATA |= (c & 0x0f);
PulseEnable;
Delay5ms();
void LCDChar(unsigned char c) {
LCD_RS = 1;
LCD_DATA &= 0xf0;
PulseEnable;
LCD_DATA &= 0xf0;
PulseEnable;
Delay5ms();
void LCD_GOTO(unsigned char line,unsigned char column)
unsigned char data = 0x80; // default to 1
if(line == 2)data = 0xc0; // change to 2
data += column; // add in column
LCDCmd(data);
Delay5ms();
while(*string != 0)
LCDChar(*string++);
That code is full of mistakes..
What is this supposed to mean:
Or this:
I think the above should be:
LCDStr("SimpleHello");
and
LCDCmd(DISPLAY_ON | BLINK_OFF | UNDERLINE_OFF);
There are many other mistakes.
LOL, Not mistakes by us but by your EYES..
SimpleHello is a variable. If you quote it, its TEXT...
The & portion depends if a bit has to be LOW( & ) and not HIGH ( | ), since the "S" character worked then i assume & is correct.
//is the same as
LCDCmd(0b00001100);
//which is also the same as
LCDCmd(0x0C);
