Fascinating- keep us posted on the progress with that one.![]()
Thanks for the update TCM ... Nice outline of the whole process.
You know nature is perverse- you build an over unity generator only the find that the ball bearings on the main shaft are faulty and the whole thing ceases up. Or there is an earthquake. Or someone invents a nuclear battery that costs peanuts and produces a 100V at whatever current you want, forever.Yea unfortunately I have an issue with the new boiler already.
I took it out of service about 4 days ago to redo the water lines to the house and epoxy the shed floor only to find that the Rustoleum primer paint I lined the inside with dissolved when exposed to antifreeze so now the thing is line with a layer of orange goo.
Its been in service for aobut 2 months now yet when I drained it the antifreeze and water solution came out looking like orange mud like something that would be found in a tractor engine that hasn't had a coolant change in 40 years.
Apparently since I did my last boiler build a few years ago Rustoleum changed their primer formula ('environmentally friendly' reformulation BS I suspect) and now it's obviously not compatible with antifreeze (or tap water?) any more.
The only proper fix will be to cut it apart and strip it and redo it with two part commercial epoxy.![]()
Rustlok Steel Primer 6980 is great stuff. It stops rust in its tracks. I use it on boats in salt water all the time. I put it on a pool pump timer box that had holes rusted through it. 15 years later it looks the same.The only proper fix will be to cut it apart and strip it and redo it with two part commercial epoxy.
You would never get it passed an airportOr someone invents a nuclear battery that costs peanuts and produces a 100V at whatever current you want, forever.
spec
