ABS Sensor Testing
What I’ve tended to see referred to in the Isuzu Workshop Manual, is a Tech 2 scanner again they are in the region of £260.
Do you have any ideas on a cheaper way of getting a scanner or program for that vehicle?
Unfortunately, no..
Same requirement for Suzuki & they are not cheap (but cheaper than letting the dealer change multiple random parts to find a fault).
You could try mine, if you are reasonably near?
rjenkinsgb thanks for the kind offer, I'm in Stafford so a fair distance from where you are.
Having said that fortunatley there's nothing wrong with my Trooper at the moment, but I can reme,ber the time when it was gobbling up fuel injectors like there was no tomorrow
Having said that fortunately there's nothing wrong with my Trooper at the moment, but I can remember the time when it was gobbling up fuel injectors like there was no tomorrow, I believe Isuzu almost went out of business as a result of the number of recalls.
It’s the 3 litre model, if you know your cars I don’t think I need say any more.
Do you use your Tech 2 in line with your occupation or just personal use?
I’m not really into scanners, so can you tell me is the Tech 2 only good for certain cars, like it could not be used on a VW motor, just thought I’d ask since you own one?
They are pretty specific to the General Motors / Vauxhall / Opel and odd things like Suzuki and the Isuzu..
It is my own, bought to diagnose a problem on a relatives Suzuki which was continuously clogging the diesel particulate filter.
There are quite a few different vehicle-specific ones for the stuff only dealers can generally access; I have another unit, a VMCII, for older Fords (and apparently Jaguar / Land rover).
The little OBDLink MX with free software on a PC or tablet is fine for most things though, it can be used to read faults and reset stored faults in virtually any vehicle - it's only the "dealer" stuff or supposedly impossible mods that need the specialised interfaces; eg. I got the VMCII to retrofit the OEM hands free phone interface on a previous car.
My present Ford does not need anything special, the OBDLink and "Forscan" program can do anything the dealers can, if not more - as well as general diagnostics.
