AC ammeter
Dr_Doggy
I am about to build an ac ammeter, i was reading that the best way to do this is to use a Rogowski coil and feed it in to a in integrator, and from there to my PICuC, (the value out from the integrator is dcv right)?
would this work?
btw, the word integrator sounds like it can add 2 signals, is that possible(AC i presume)?
In this case the term integrator means low pass filter. The output will still be ac.
http://www.dynamp.com/dynamp/ldadocum.nsf/c2270fbdd892ac3e86256e75000ad88a/e710af6d3e0f6255862565d7004b19db/$FILE/Report.pdf
so I would rectify it, then to the pic?
is there a better circuit I should use>?
How much current? What frequency?
Hi doggy,
check out Allegro-micro for current sensors.
There are bipolar sensors in the assortment which can measure AC and put out DC-voltage depending on the current range to measure.
Boncuk
120v mains... up to 20amp should suffice,, although i want to measure phantom power from electronics as well, im thinking mostly about reading a typical power bar.
Hi doggy,
if the prophet won't come to the mountain the mountain will come to the prophet. :)
Here is the data sheet of the Allegro-micro ACS758. It has an internal resistance of 100µΩ and the bidirectional version measures ±50A with an almost linear output voltage of 40mV/A.
That should be easy to use.
Boncuk
  • ACS758.pdf
TY very much, Boncuk, I tried to climb that mountain, but I found it hard to read the data sheets, I looked up that part number @digikey and they have it, could you just confirm that I have selected the right one, since that number I punched in got me several results:
Digi-Key - 620-1322-ND (Manufacturer - ACS758KCB-150B-PFF-T)
and this puts out a DC voltage, relative to the ac current in?, this chip looks like it supports 240v too(not req'd thou)?
