By "not as good", I hope you mean that "charge" is not as descriptive as "energize" when referring to a voltage across a capacitor. I don't see how energize is ambigous.
>I thought i made that clear with the light bulb. The light bulb being energized does not charge up, while the capacitor does. Thus, if we say energized it doesnt seem as clear.
Certainly not. Turning on a light bulb is certainly energizing it.
>But it's not charging so i couldnt say charge. It's not going to be holding anything, while the cap does hold something.
Clear because it has become an accepted description that you mean you are going to electrically energize it. Not really true, however, because it does not contain any more charge after energizing it that it did before. But, it does contain more energy.
>So you dont accept the term 'charge' that is known by the world over. Remember this for later.
From knowing what it is and the context, most folks would assume you mean electrically energize.
>Most folks? So now we can go with the normal human assumptions but for the word 'charge' we can not? What if i pour acid into the battery?
Could be either one or both. If you said "charge", what would that tell anyone?
>Charge implies that something is being stored. Energize does not make that distinction. If i say that i energized a circuit you wont know if it is storing any energy. If i say i charged a certain circuit you know something is being stored.
It depends on the component, the state of the component, and the circuit.
>For 'energize' yes, we dont know.
>For 'charge' however we know right away.
I think both words are precise when used in the proper context. I aver that "charge" is often not used correctly. Often "energize" is the better word to use.
>Ok if you want to say that that's up to you. Im not saying that it is totally wrong either, just that 'charge' is not only accepted, it is descriptive if you look at it as charge being stored and then dumped later. It acts like it stores charge so we say 'charge'. There are a few different views on what really happens too including virtual particles. Im not sure i want to get into that one though![]()
Negative. Current does not exist through a capacitor, and charge does not flow through a capacitor, unless there is leakage. Your next statement says as much.
>Well, depending on the view i guess. External measurements would say otherwise too and the external measurements are important in analyzing circuits. If we connect a constant current generator up to a capacitor we couldnt have a complete circuit unless there was the closure of the path so it would not start to store energy if there was not a complete circuit there. It's hard to say that no current flows 'through' the capacitor. Who cares really? If it goes in one side and appears to come out the other side and always works that way we're all set.
You asked what is flowing. Charge would be correct, and flowing means moving charge. Current is also correct, because moving charge defines current. Energy is also correct because energy changes when charge moves through a resistance.
>Yeah but when we think of energy we think of E=1/2 C*V^2, and although that is very descriptive of the energy it doesnt tell us what is happening an infinitesimal distance from one of the plates.
MrRB,
You were taught a simplified explanation which is not quite true. Charge does not flow through the capacitor unless leakage is present.
That's the problem with being pedantic, you try so hard to be clever that you end up being the opposite.
I never said charge flows through the capacitor. I said current flows through the capacitor.
I'm guessing you're one of those guys who went to Uni and learnt all the *wrong* things..
Like arguing with guys who have decades of experience that you may instead have learned something from. I know enough about some of the people you're pedantically arguing with to know you're well outclassed.
If i secretly label two identical sewing needles one with 'A' and the other with 'B' (using a coded micro printing) and hide them in a haystack and someone comes along and wishes to sew a button on their shirt so they hunt through the hay and find one needle, which one did they find? The answer is that it doesn't matter because they are identical so they can use either one to sew the button on the shirt and the outcome would be exactly the same no matter which one they found. In other words, the needles loose their identity in the application of the reality of the situation. If we have two particles we can not even label them so if one flows in and another flows out, we can call them not only current flow but we might even say they are the same exact identical particle (like the sewing needles). Interesting if you ask me.
Then you would be wrong on two counts. Current does not flow, and no particles flow through a capacitor unless it leaks.
I'm genuinely interested in hearing you justify that statement.
Mr RB,
OK. As you probably read in my previous statements in other threads, current is charge flow. So when you say "current flow", you are really saying "charge flow flow". That is redundant and ridiculous. Therefore, when publications and folks use the term "current flow", they are using a quirky phrase that has been used so often that no one thinks about it anymore. Folks should instead say charge flow or current exists.
Ratch
"Current flow" is perfectly fine.
It's part of our language and if you read up on language you'll find that the word "flow" might be redundant but that is also perfectly fine in language because it puts emphasis on what is happening.
On the other hand, if we say instead, "Charge flow", which is what we believe is happening, we have to invoke a lower level term in the language that refers us to something that we really dont have to pay attention to in many many cases.
E=R*I for example, we might say that I is the current flowing, and we say that because I stands for current, not charge, as we have another letter that usually represents charge, namely, "Q". So what you are suggesting is that whenever we run across E=R*I we have to instead think about E=R*Q*t, which is too much detail for the level we are working at. But at the same time we want to make sure we convey to another person that something is definitely moving, so we say "Current flow" to emphasize that fact.
It's redundancy in language, and it's allowed.
It should also me noted that it's use is more or less in a more casual forum too, rather than a strictly scientific one.
Like Ron I have been around a long time.
I found that from my earlier years it was important to recognise people who are a time wasters and to make sure they didn't waste my time.
Such words as 'current exists', 'voltage appears', 'later slows up and finally stops'
'DC voltage is stopped'
Not being factually wrong doesn't make it useful. In fact, as a description, it's almost completely useless.
We talk about the flow of current to convey useful facts; which way it flows, with what intensity it flows, etc. Even those of us who have spent a lifetime studying electronics find these abstractions useful.
Nubes should evaluate our arguments and use whatever suits them.Noobs are encouraged to use them as will.
I aver that the redundant phrase "current flow" does not convey any more useful information than "current" does. One could say forward current, backward current, or any other direction.
I too have spent a lifetime studying electronics as a hobby, and I find some descriptions literally misleading and sometimes redundant.
