Mr RB
So you see we are really at the place where we want to discover if the displacement current is a real current or just a byproduct of an equation. ... Now the only argument left is about the displacement current, is it real or not?
Now I think you are asking a much better question.
As for displacement current being a REAL current, I'm pretty much in your camp. I think the best definition of a "real current" has to be conduction current of electrons flowing through a conductor. Once we start to move away from that definition the current must become less "real".
Forget caps for a second and think of a transformer. As current goes into (loosely) the primary there is a physical field effect inside the transformer and causes a current to come out of (loosely) the secondary. (I say "loosely" in an attempt to ignore the fact the transformer has 4 wires not 2).
So if this case is analogous to what is happening in a cap, (and in some ways it is, as there is a current in, current out and an internal field effect) we would probably have no problem sayng "there is no REAL current flowing from primary to secondary".
The transformer may be a stretch of an analogy, but to my simple way of thinking any time you have 2 divided systems with no direct conduction, and current is only INDUCED across the divide, cannot be classed as a "REAL current".
But I still don't mind the term "displacement current" in a conceptual use. Then again I don't mind calling a "battery" "flat" even though it may be very round and it might even be a CELL.
If someone said we were not allowed to say the battery was flat I would argue because the term "flat" is conceptual and does the job quite nicely thank you. If nobody knew what a "flat battery" was, then that would be a different case. If you want to eliminate commonly used and well understood terms that are not 100% perfect you have to throw away half of the English language.
