halleffector
Hi halleffector,
What is the history of this motor before your first post. (I.E. Did it come from a scrap yard ? Did you remove it from a machine that had just stopped working ?) Can you post a picture of the inside of the connection box on the motor. Just with the cover removed. Do not disconnect any wires. Is there a centrifugal switch on the end plate that has been removed ? (Or on the one still fitted to the motor ?) Can you trace out the wiring of the windings as it is not easy to do just from pictures as some wires are hidden by wires in front of them. There should be four ends of the enameled wire of the windings. Can you mark them in some way to identify them and take resistance measurements and post the readings. (I think that will result in six readings.)
Les.
This motor was in working condition and pulled from a log splitter once the motor failed. The mode of failure is unknown but the motor would seize on multiple occasions when cutting large logs. This has probably contributed to abnormally high loads. Possibly related to burn marks? There is not supposed to be a centrifugal switch to my knowledge.
I will try to trace out the wiring as suggested.
