Buy a multi-meter and you'll be able to measure a lot higher and lower voltages than that.pursang said:I'm having trouble finding a local distributor for this particular brand of plug in household voltage meter, I'm wondering would it be possible to build one of my own, what parts would I need ? thank you in advance.
I have a surge protector that has a "surge" breaker on it. If it gets to be around 5V over it'll flip the breaker on you, which is nice if you're using a generator with big loads connected to it that turn on and off,losta spikes.Hero999 said:It sounds like you want some sort of over-voltage protection circuit. There must be a product available that will shut off the generator when the voltage exceeds a certain level.
A power factor meter might also be handy or you could just install some sort of active power factor correction unit.
