adc conversion
what's the solution for the adc conversion?
  • increase the delay in the program
    Votes: 0 0.0%
  • add any component to the circuit
    Votes: 0 0.0%
  • change the impedance
    Votes: 0 0.0%
  • Total voters
    0
elie
Hi, i would like to ask about a certain problem occuring with me during the adc conversion..instead of converting 4v for example to the right binary number at the output..i'm always getting an answer at the output less than arounf 0.5v from the real voltage at the input..what's the solution?
No one can make make a qualified judgement without seeing both your source code and full circuit diagram, you do not even mention the micro or programming code you are using.
Please post them so we can look into your problem more.
I am puzzled why the OP thinks this problem, which is specific to his project/program is a topic for a POLL.???
IMHO it belongs in the micro-controllers Forum
the pic number is 16F877...this is part of the source code:
A2D_CHANNEL_0
MOVLW B'01000001'
MOVWF ADCON0
CALL A2D_DELAY
BSF ADCON0,GO
BTFSC ADCON0,GO
GOTO $-1
MOVF ADRESH,W
RETURN
hi all, in my project i'm using different types of sensors on a multiplexer and they're all going through adc conversion. if the output of one sensor is 4v for example, the microcontroller sends 3.5v after converting it to digital..there's always this gap in the voltage...should i place any voltage buffer after each sensor to prevent this drop down or what?
A2D_CHANNEL_0
MOVLW B'01000001'
MOVWF ADCON0
CALL A2D_DELAY
BSF ADCON0,GO
BTFSC ADCON0,GO
GOTO $-1
MOVF ADRESH,W
RETURN
You're only showing a tiny part of the code, and if you're only reading ADRESH then (depending on the setup) you're only reading the top two bits.
Check my analogue inputs tutorial.
yes i'm only interested in the highest 8 bits and i want to neglect the least 2 signigicant bits since the encoder connected to the microcontroller can only read 8 data bits and not 10
What multiplexer are you using ?
But you've shown no code to suggest that's what you're doing - it's useless posting only what you have.
