mircea1981
Hi.
I am a beginer in pic microcontroller and i need some help. I have a development board from Microchip, PICDEM Mechatronics with a pic16f917 microcontroller.
I use MPLAB IDE v8.70 and HI-TECH ANSI C Compiler.
In code if the current provided from a potentiometer is less than a threshold (2.5 V) the diode D0 must be ON, else OFF.
When i run the code in debug mode i receive the next error :
ADC-W0001: Tad time is less than 1.60us
ADC-W0008: No stimulus file attached to ADRESL for A/D.
I do not understand why i receive this error since the Fosc is 8MHz, AD conversion clock is 16.
So, with this setings i computed the
Tad = 2 microsec.
The code :
Tad = 2 microsec.
The code :
C:
#include<pic.h>
__CONFIG(FCMEN_ON & IESO_OFF & CP_OFF & WDTE_OFF & BOREN_OFF & MCLRE_ON & PWRTE_OFF);
#define ZERO 0
#define ONE 1
unsigned int ADC_result;
unsigned char ADC_channel;
void Clock_Init(void)
// Internal Oscillator Frequency Select bits - 8 MHz
OSCCONbits.IRCF2 = ONE;
OSCCONbits.IRCF1 = ONE;
OSCCONbits.IRCF0 = ONE;
// Set the ADC clock frequency Fosc/16 = 500 KHz
ADCON1bits.ADCS2 = ONE;
ADCON1bits.ADCS1 = ZERO;
ADCON1bits.ADCS0 = ONE;
void Comparators_Init(void)
// Comparators Off
CMCON0bits.CM2 = ONE;
CMCON0bits.CM1 = ONE;
CMCON0bits.CM0 = ONE;
void Port_Init(void)
// Pin RA3/AN3 is set input
TRISAbits.TRISA3 = ONE;
// Set RA3/AN3 to analog mode
ANSELbits.ANS3 = ONE;
// Set RD7 as an output
TRISD = ZERO;
PORTD = ZERO;
void ADC_Init(void)
// A/D result left justified
ADCON0bits.ADFM = ZERO;
// +/- Vref.
ADCON0bits.VCFG1 = ZERO;
ADCON0bits.VCFG0 = ZERO;
// Analog channel 3 selected
ADCON0bits.CHS2 = ZERO;
ADCON0bits.CHS1 = ONE;
ADCON0bits.CHS0 = ONE;
// Select ADC Channel
ADC_channel = ADCON0bits.CHS;
// Switch on the adc module
ADCON0bits.ADON = ONE;
unsigned int ADCRead(void)
// Start conversion
ADCON0bits.GO = ONE;
// Wait for the conversion to finish
while(ADCON0bits.GO == ONE);
ADC_result = (ADRESH<<8) + ADRESL;
// Switch off adc
ADCON0bits.ADON = ZERO;
return ADC_result;
void main (void)
Clock_Init();
Comparators_Init();
// Init port pins
Port_Init();
// Init ADC
ADC_Init();
// code will run in for loop forever
for( ; ; )
// Read Channel 3
ADC_result = ADCRead();
if(ADC_result < 2.5)
PORTDbits.RD0 = ONE;
else
PORTDbits.RD0 = ZERO;
