ADC value to LCD with PIC microcontroller
ravi17
I am trying to send ADC value to LCD with PIC16F877A but only the first digit is displayed(picture attached). Can anybody help? here is the code:
void main(void)
sys_init();
lcd_init();
unsigned int adc;
int v;
char a,b,c,d;
while(1)
adc = adc_read();
v = ((adc*5)/1023)*100; //eg v=234
a = v%10+48; //4
b = v/10; //23
c = b%10+0x30; //3
d = b/10+0x30; //2
send_string("Volt: ");
send_char(d);
send_char('.');
send_char(c);
send_char(a);
__delay_ms(1000);
send_cmd(0x01); // clear the screen
the ADC code:
#include "adc.h"
unsigned int adc_read()
GO_nDONE = 1;
while(GO_nDONE);
return ((ADRESH<<8)+ADRESL);
the LCDd code:
void send_char(char data)
RS = 1; //select Data Reg.
PORTD = (PORTD & 0x0F)|(data & 0xF0); //send upper nibble
EN = 1;
__delay_ms(1);
EN = 0;
PORTD = (PORTD & 0x0F)|((data<<4) & 0xF0); //send lower nibble
EN = 1;
__delay_ms(1);
EN = 0;
Debug it, add the line v=123; after the line v = ((adc*5)/1023)*100; //eg v=234 and then you'll know where the error is. It could be the ADC reading or the displaying.
hi Pommie,
thanks, when v =123 is added the digits are displayed correctly.
i have tried debug but couldn't figure out how to get the variables window in proteus.
so what we know is that v = ((adc*5)/1023)*100; is creating the problem. I tried by changing the data type of v but not working. I think the conversion eqn. is ok.
could you perhaps give more insight??
I'm just a braindead Basic programmer but won't this equation be done in integer math?
Try rearranging it to:
v = ((adc*5*100)/1023)
(adc*5)/1023 will only evaluate to one digit in integer math.
The maths needs to be done in a 32 bit variable as ADC*5*100 can be over half a million and a 16 bit integer can only hold 65535 maximum.
Try making v a long and do the maths 1 bit at a time,
unsigned long v;
    v=(long)adc;
    v*=500L;              //may not need the L at the end
    v/=1024L;
Note, see thread on why it should be 1024.
Edit, added cast to long.
